I have a worcester bosch 19/24 cbi. It was very noisy, however after using some fernox f2 this has dramatically improved.
The issue remaining is that when I switched on the hot water, the boiler fired up for initially about 15 minutes, then went off for 3 or 4 minutes. After having been on for about 30 mins, I checked again and found the boiler was only coming on for an ever decreasing amount of time. 2.5 mins on then nearly 4 mins off. This reduced down to 1 min 10 seconds on and 4 minutes off, before the water got up to temperature (60c) after about 1 hour 15 minutes.
My Central heating engineer, thought it may also need a new heat exchanger. Is this normal behaviour or could it be a sign of scale build up on the heat exchange shutting the boiler off so quickly?
