Scantronic 9448+ with 9427 keypad
5 Jan 2007
London
Hi folks
I have this alarm system and am thinking about turning it off completely. And I mean completely
There is no dedicated switch on the main’s electric board for the alarm. If it had one, I guess it would be easy to switch alarm off and remove back up battery, I assume.? Hmm
Now my question is, if I remove the 5A fuse to the control panel and then remove the backup battery, will that just turn the whole alarm system off with no surprises? Am guessing in theory, it should as there will be no power to the control panel, external sounder and internal sounder, right?
Am a bit worried removing the 5A fuse( cuts electrical power to control panel?) and disconnecting the backup battery may activate the alarm and of course I won’t be able to silence it.
Can anyone tell me what will happen or a better way to completely disable it?
Worst case get ladders out or wait 20 mins for the cut out timer to kick in ….post picture of external bellbox
Thank you for the response. Photo attached.
So effectively you are agreeing with my plan as the way to disable it but in case the alarm goes off, only way is then to climb up to the box, open it and rip the sounder out? sounds like I may have to attack the box
Any tips when box is opened. Never seen the inside of one of these before.
Thank you mate
Look for a battery , could be like a C cell with a red and black wire going to the pcb just remove one of the wires
CQR INTEGRA
