Around 6 years ago we had rockwool cavity wall insulation installed, along with new double glazing. However now we have a damp problem that is showing itself up as black mould along the skirting board of two outside walls (north and east facing), and on the same walls but in the bedrooms. A local builder suggested the isse is due more to condensation as there is an imbalance in the heating / ventilation / insulation triangle. However as the house was built in the 1950's he can't rule out an issue with the damp course being breached, say by an dense deposit of the cavity filling
I've been searching the web and found a possible alternative to having a replacement DPC fitted. It's called the Schriver system and seems to involve fitting special "bricks" every 18" or so along the outside walls
I was wondering if anyone has had this fitted and if so did it cure the problem. - - - - - - - - - - - - -
Cheers
Malcolm
Cheers
Malcolm
