M
Maylinda
I have a novice question - with the huge array of fasteners available, how do you know which type is the correct one to use? Is there a chart that says if the wood (or metal etc) is X dimension use Y screw? Obviously if you need to screw or nail through 3 2xW members you need a longer fastener - but how is the diameter chosen correctly.
in short - assuming all variables are the same, why would I use a #8 1" Screw versus a #6 1" Screw?
