setting radiator flow with weather comp
19 Dec 2017
as i have pre-settable rad valves im trying to figure out what temps i should be setting them for and what return temps etc
take a 500x1600 t22 what temp should i using as flow and return?
should it be the max temp the boiler will use at -3? id likely be using 36.2 based on my current curve so do i set for that and what sort of temp drop should i be trying to get as my room temp is set for 20c it cant be physically any more than 16c and id never achieve that anyway
also the calculator for setting wont go below 40c flow and most of my time will be using temps lower than that anyway so im getting confused
so i have really no idea what i should be using
