Shower outlet threads to short.
11 Sep 2008
Edinburgh
Hi
I have fitted a concealed shower valve and can still gain access to the rear of it.
My problems is fitting the outlet valve which supplies the shower head (see my images). When the tiles are fitted the threads on the valve are to short and do not appear through the other side. Therefore I cannot attach the outlet pipe from the valve.
Please can anyone suggest the best way to tackle this problem.
Regards
Paul
Hi
Thanks fro everyones help.
I have Uploaded my new image and taken the option to "Show my images" hopefully now you should see the Image of the shower outlet. :oops:
Regards
Paul
Hi
Thanks for your mail. I'll try and get a couple of pics and post them in. If the outlet threads were about double the length that would solve the problem but lookig at other examples on the Net. This looks like the standard length of thread. So I'm thinking you have to fit some sort of connector between the outlet and the outlet pipe.
Regards
Paul
should have a 1/2" thread on the rear that go's in to a 1/2" wall plate.
Hi
That looks like the sort of thing I am after.
Thanks for your mail. It does have a 1/2" thread. But looks like I still may require a cooneting piece.
I take it the wall plate screws into the back of the false wall not the front of the tiled area.
Regards
Paul
screw the wall plate in the wall (false or brick) so the front of the wall plate is about level with the finshed tile.
has the outlet connector not got a threaded part out the back ?
Hi
It has got a threaded part out the back but its only 15mm in length.
If I screw the wall plate to the outside of the wall it looks like the water feed to it will be on the wrong side of the wall (the wall is made of wooden board) . i'e on the Tiled Part of the wall.
Should the wall plate be secured behind the wooden board wall ? So its hidden
Regards
paul
Get some 15mm tap connectors solder some pipe to it so they will go through the hole, stick them on your shower then fix your shower to the wall. job done.
Hi
Thanks for your mail. I've Plumbed it with Flexipipe and push fits (as I'm not a Plumber :LOL: but really enjoyed the experience. Would it still be ok to use 15mm connectors with this. I take it the pipe would have to be fixed rigid at the back so the connectors don't come through hole.
Regards
Paul
fix the wall plate to a noggin in the wall.
then fit the plasterboard and tiles.
