gman76 said:jammed
moved
He he!
fixed
confused
If, by that, you mean "am I capable of describing something unambiguously, and of knowing when to meddle with a switch and when to replace it, and of knowing when it's appropriate to joke about electrical safety", then yes - I'm barking mad.gman76 said:are you insane?
Er, no you didn't. The only 'good' action would have been one of:gman76 said:Sorry Softus, but your last post confused me a little, all I did was make the shower switch good for as long as took for the landlord to replace it
Since my suggestions included replacing the switch, you continue to surprise me with your inability to either read or write.gman76 said:Oh come on, are you suggesting that I do nothing until it's fixed?
Hygiene over fire safety? Yeah, of course - since I'm insane I'm bound to agree.I need to shower mate, I'm sure you'll agree.
It makes no difference to the fact that you did something that was unsafe, nor to my warning to other readers.gman76 said:Yes, and if you'd read my posts, you'd realise that the work has already been done.
Let's not forget that you first addressed a post to me, not the other way around.I don't want a fight with you Softus, the idea of this forum is not to create friction I guess!
I'm quite happy to accept them, but I assure you that they really aren't necessary. I thank you anyway.gman76 said:Firstly, Softus, please accept my apologies, I wasn't attempting to be rude or start an argument.
It thought you'd said that it was faulty, and you took it apart, and that "jammed" it in position.Which part of changing a switch contact from the off position to the on position would be risky?
It depends on how you jammed it. For example, if the thing or method you used was affected by heat, and allowed the contacts to begin to separate, then the contacts could overheat, and overheating is the start of most electrical disaster stories.Surely the current drawn through the contacts would be the same as when the switch was operating normally?
I suppose it's not beyond the realms of possibility, but could you enlighten me as to the meaning of your question?Crafty said:You on the blob softus?
I now can't why it wouldn't be.gman76 said:So hopefully it was safe!
I'm in no doubt that "jammed" doesn't describe what you did. All's well that ends well, I s'pose.Perhaps "jammed" was the wrong expression, as I didn't add anything to it - like a nail in a fuse holder!
