Hello All,
At present I have a surface mounted shower switch located on the wall inside the bathroom with ugly surface plastic conduit. The switch is at sort of shoulder height with the cables going out the top and bottom, up through the ceiling and down through the floor. It is exactly as it was when I moved in 8 years ago.
By all accounts this is not allowed.
We are thinking of moving house so I figure this needs to be changed. I guess there are 2 options.
1. If there is a bit of slack I can bury the cables in the wall and take them through the other side of the wall into the hall and have the switch there at a similar height.
2. Pull the top wires into the ceiling and somehow extend the lower section that comes out the floor so that it can join those above the ceiling and have a pull cord switch.
Any guidance as to my best option would be appreciated.
