SHOWER WASTE SIZES
13 Feb 2005
I fitted a shower trap that came with my low profile tray but when used the tray simply filled with water. I have plenty of space under the tray so am going to fit a normal P trap with a chrome waset that screws down onto it.
The problem I have found is the differerence in flange sizes of the wastes. I have already ordered this product:
http://www.trueshopping.co.uk/produ...with_easy_clean_lift_out_grid./522/37925.html
But on measuring the hole where the waste sits it seems the hole is 70mm, and i've worked out that 2 7/8 inches is 73mm. Will I still be able to fit this waste, perhaps by using silicon sealent to fill the void or is best to buy this product:
http://www.thebathroomlook.com/show...r-wastes/70mm-high-flow-shower-waste_122.html
Why are manufacturers making shower trays with a difference of 3mm in flange sizes for the wastes ??
maybe he don't know we use metric now days.
What gets me is that a lot of sellers are even mixing up metric and imperiial on the same product i.e 70mm flange and 1.5inch tail.
Anyway that still doesn't help with my original question.
Will a 73mm waste be suitable for a tray with a 70mm flange or are all shower trays basically the same and its just the conversion from imperial to metric that causing the problem. Although I have seen wastes stated as 70mm and 73mm so I'm presuming that shower trays have either a 70mm or 73mm groove for the flange.
