I had a 7kw shower and I've upgraded it to a 8.5kw shower. I've changed the wiring from 6mm to 10mm, the old shower unit had a seperate supply from the cu with a 30A fuse. My new shower is 40A but I can't use it at the moment as I've bought a RCD with a 40mcb, but I can't isolate the tails from the meter to the shower supply to change it to the RCD. Would it be possible to use the shower with the current fuse or would it definetly blow straight away? Also I'm thinking about cutting the seal on the main incoming fuse so I can change the shower supply over. I've just bought the house and it is the original wiring, so it's got to be 35 yrs old, but the shower supply was put in 23yrs ago I've worked it out. I could possible lie about the seal already being broken prior to moving in if anybody asks. The original shower supply fuse carrier was an mem, I've found it impossible to find a 40A mem fuse carrier although I'm sure it would be easy to find a 40A fuse. I would like to put in the RCD though as it cost me 40 quid.
