I have a showers its not electric or anything but the part where you turn in the middle between the hot and cold tap you use that to change to bath or shower the water keeps gushing out of that part could it be that the valve has gone?
Could be, or hose /head is blocked, try removing the shower hose from the taps, switch over to shower on your shower assembly & see what happens. If it still p*isses out you need to look at the body, maybe remove & renew.
looks like a cheap nasty mixer with a pair of Bristan Victorian tap revivers fitted. Hose looks s4agged .no wonder it leaks. replace hose as a start.may be excess back pressure if kinked inside.
Nope it is the taps you are correct yea i was think of replaceing the whole lot looks a bit knackered the water comes out the middle part where the mixer is its hard to take a decent shower at moment
