Plumbing newbie here (if you couldn't tell)...
Our sink suddenly stopped draining tonight so I tried the old plunger. No luck. Quite a lot of resistance with water coming back up the overflow etc.
No unblocker to hand, so I dismantled the undersink pipes. The weird thing is, there was some gunk but no major blockage as far as I could tell. Tried tunning water through it and also the back pipe - flow seemed OK.
One rubber washer is broken, which is causing a trickling leak so I'll replace that. But can that alone cause a sink not to drain? My elementary physics tells me there must be something else??
Any help appreciated.
