Yes, third post in this thread...Ok so i had a little pun@ slugbaby....but slug,lump, clod. same thing . IT`s so simple . the sink pipe goes to a bigger vertical pipe(block of flats) I`ts blocked somewhere. I rest my case M`Lud.trickiedickiedido said:Thanks for the offer Nigel. But can you think of anything that might cause this phenomenon?
Nobody answered Bahco's question from way back, and looking at the photo, I think he has a good point. It looks to me as if the horizontal pipe disappearing behind the back panel of the sink unit does in fact run uphill.Bahco said:Does your waste pipe have a fall on it?
Slugbabydotcom said:Another idea I have, fresh from the twilight zone, is that some floatey material eg fat or polystyrene has created some sort of valve somewhere. Pretty rare but you will be amazed at some of the things we see. 3rd post on this thread........always knew I was in a strange zone
trickiedickiedido said:I have a very similar problem. My S bend behind the washing machine is trapping water. Like this post, I've removed every bit of pipe work (even removed the kitchen units to do this!) and cannot find ANY sort of blockage. Basically the grey hose from the washing machine goes into a long vertical pipe then into the s bend. The water will go through but after a few seconds the vertical pipe fills up and over flows. This is driving me nuts. I am quite handy at DIY and this has me stumped. I begrudge calling in an expert who will charge me around £50 to point out something obvious! PLEASE HELP! Failing a result here I think I'll call in the local priest.
Ricahrd
joe-90 said:When he tests the pipe the water flows - AND THAT IS BECAUSE HE DOESN'T TIP ENOUGH DOWN TO SEE IT BACK UP!
