Hi there, we have a DWF1 which up until now has been working well. Has had a few issues in the past and has had pump impeller housing replaced (seal leaking) along with the main tank to the side (blocked), float switch.
Started acting up again so fully cleaned out including pipework.
Now refuses to fill.
Select program, 2 beeps, starts but stops instantly. No fault code shown. Manually force machine to empty using float switch but it will not take on water.
Any ideas apart from the obvious, buy another one, call an engineer (lost confidence in engineer as took 5 attempts and numerous attempts to cure previous faults seemed more like guesswork than skill!)
Worth salvaging so thought I'd try here first.
Thanks for any help/advice in advance.
