Smelly drain
Ok thanks will try and see what I can hook it up with as it keeps falling down. That would just be dirty water from the sink going down there? Do you think that could be it although I wouldn't say there is much dirty water that goes down there.
Loop a piece of string round the hose and tie it up to hold the pipe. Can't say for definite that is your problem, but it's not correct procedure, and won't help matters. Until it's sorted you won't know.
That's what I was thinking of when I get home, maybe a cable tie or something to hold it up. What water would be discharging into this though, from the sink or dishwasher?
On another note and not sure if it's related but after we had the new washing machine installed, we are getting a gargling noise when it spins and I've read that it could be trapped air.
This is about the best I can do with the slack I have. Doesn't seem much but hopefully enough
Is there space to bring it up the other side of the right hand unit and over the top instead? That would be better.
Unfortunately not and doesn't appear to be any more slack on the cable
