I have an unidentified lead pipe running up the corner of a wall which I would like removed.
There was gas in lead pipe in the property but the only gas now in the property runs in copper from the meter to the boiler, so if it was gas then the pipe is no longer connected.
It may be a deadleg on the water system coming off the incoming main, pre the current stopcock and, as I said, I would like to remove it.
What are my options. I presume it needs to be nipped closed and soldered over. Without causing offense, is this something today's plumbers could be expected to do ?
andytw
andytw
