hi i'm new to this so just hope someone can help.
i'm moving my trianco boiler out of the kitchen and into the garage , i have heat leak gravity fed rads upstairs the down stairs is pumped , also the hot water tank is upstairs and i suppose this is gravity fed using 28mm pipe , what i need to know is that when i move it will everthing work the same , the pipe work from the kitcen to garage will be undreground and travel about 18ft , my pipes at the minute go upwards so i presume this makes it gravity fed, but they will when moved come out of the boiler downwards before eventually going up will this still heat my hot water or will it need to be pumped, thanks please can someone help asap
