split loads help
15 Oct 2009
Kent
hiya
i have a barn that is being split in two, each side requires to have a ring main and lighting circuit, also each side needs to be metered indepenantly of the other, and just to add to the mix i have three phase power available to supply the barn, i have 2 meters, and i also have 2x 4 way consumer units with the circuit breakers in each and a 30mamp rcd, my question really is can i use a 1 phase into the meter on one side and then another phase for the other side leaving 1 phase reduntant or do i need to go into one of the large split load consumer boxes any advice would be appriecated
many thanks steve
the 3 phase supply is already metered by the supplier before it its my main board in another barn,i can take a 3 phase supply from this main board over to the barn im working on, i have 2 people who want hobby rooms in another barn which they want lights and sockets, so i want to meter the power there using
hope this clears thing up a little
