col
even the beggars have air con here its just a question of what sort
Posh gits!col
You need to close the bracket at the beginning Col.
EDIT: Sorted.
Does the fact that smell is directly related to the heat mean anything? The hotter is outside the worse the smell.
Take a look at this from your part of the world.
http://www.iaei.org/magazine/?p=2719[/QUOTE]
Very interesting. Helpful too. Thanks!
What in the USAit's very unusualyou might also consider an Energy Saving lamp .
it's very unusual to find mould inside a light fitting, as the heat of the lamp usually keeps them hot and dry.
Is there any chance a nearby water leak could have got into it?
you might also consider an Energy Saving lamp to replace the old bulb, these run a lot cooler and use less electricity. This is just in case the mould was insulating the lamp fitting and it was getting too hot.
Please note rule 1 (Abusive or unhelpful posts are not welcome.) - See here for the forum rules.
there's nothing to be gained by being unpleasant
