I had assumed it was obvious, but we're talking about an unsigned mean - the mean of |V| if you wish.The mean of a sine wave is zero!
Exactly. As I wrote:For a resistive load P=I²R=V²/R Where P is average power, V is RMS voltage and I is rms current. This is what makes RMS voltages and currents interesting and applies regardless of whether the waveform is a sinewave or not.
As you point out, I should have added that I was talking about resistive loads.We don't use RMS just for the hell of it - and,in some senses,it is even more valuable for non-sinusoidal waveforms (since there is a simple arithmetic relationship between RMS and mean for a sine wave). ... RMS current multiplied by RMS voltage will always give true power, regardless of waveform, whereas the same is not true of any other sort of average (such as the mean).
Indeed, if instantaneous current is not proportional to instantaneous voltage then the RMS current times the RMS voltage will no longer be equal to the mean power.As you point out, I should have added that I was talking about resistive loads.
That may or may not be true - but, if you read the whole thread, you'll see that the extremely low apparent voltages seem to exist throughout the OP's house - not just in the workshop.Get the electrician back, the cable supplying your workshop is undersized.
If the electrician who wired the extension did any testing at the time, presumably (s)he would have picked up very low voltages (had they been present at the time) and, as you say, reported it to the DNO. So, either the electrician did no testing (the OP seems to have disappeared, so we can't ask him about documentation) or else the low voltage situation has arisen since then. Whatever, as you will have seen, the OP was advised to contact his DNO.Well, if that's the case,the electrician should have notified the DNO.
Fair enough. I think the 'enjoyable' (for some!) off-topic bits have probably reached their logical conclusion. If the supply to your house is intermittently anything like as low in voltage as you were indicating, the DNO certainly need to look into it. I'm surprised you haven't seen them yet - in my, albeit limited, experience, DNOs seem to be very quick in such circumstances (often within hours!).I'm still tuned in to this thread and check back every so often but it went a little off topic but I didn't want to stifle the chat people seemed to be enjoying! My electrician and I did chat about the low volts but it was/is only ever intermittent. I have reported it to UK Power Networks who of course promise to respond within 24hours... 3 days encounting!
Just out of interest do any of your neighbours experience the same problems - are you last in line from the overhead power line?I'm still tuned in to this thread and check back every so often but it went a little off topic but I didn't want to stifle the chat people seemed to be enjoying! My electrician and I did chat about the low volts but it was/is only ever intermittent. I have reported it to UK Power Networks who of course promise to respond within 24hours... 3 days encounting!
