Hi - New here (slightly dim about DIY/building)
I am converting a barn (you might get fed up of hearing about it)
Currently it is a single skin of breeze blocks on a base of 8 inch concrete
I am planning on putting down a damp proof membrane on the floor, laying a wet underfloor heating system, screeding over the top.
Putting some sort a damp membrane on the walls the 2 inches of insulation, the doing a stud wall, insulating it and plaster board over the top.
Will this work?
Or do I need to put an extra sheet of plaster board (or something) between the 2 inch insulation and the stud work?
Any helpful suggestions or thoughts?
TIA
Katymac
Will this work?
TIA
Katymac
