Suspected faulty/ broken detector
8 Oct 2008
London
In a recent adventure decorating my house. I unscrewed one of the detectors, an Optex RX-40QZ, to paint around it. When attempting to secure it again my screwdriver accidentally touched one the back of the circuit board, then smoke started appearing and the alarm went off. I went to turn off the alarm and then noticed the led light on the dectector was now constantly on and when I try to set the alarm it immediately thinks there is a tamper/ suspected intrusion.
Questions:
1) Have I fried the detector?
2) Is there anyway I can switch/ unplug off the detector and set the alarm as the other detectors in the house are fine?
3) Can I easily replace the detector if I was to get a new one following the existing wiring?
Any advice would be great.
Thanks in advance,
Mehul
Most detectors have a terminal strip with 6 connections , usually labeled
C , C or AL -AL , these are the alarm circuit
T , T or TAMP , these are the tamper circuit
12v , 0v , these are the power connections.
As long as there are no resistors or ID chips across these terms , then you need to isolate the power wires (from each other) , and connect the tamper wires together , and connect the alarm wires together.This will allow you to use your alarm without that detector.
You may have also blown the AUX fuse , usually about 1Amp 20mm.
Most pir detectors are wired similarly.
Hey Denford,
Thanks for the advice. Do I need to power down the system, before I connect the relevant wires together to avoid blowing any fuses?
I have already replaced the AUX fuse, so that should be fine.
Cheers,
m
yes, power the system down.
You have already learnt that accidents happen when working on powered up electrical equipment, now power it down any other time or you may well end up causing more damage :D
Whatever the smoke start appearing from needs replacing.
I doubt it was the screwdriver that started to go up in smoke, so more than likely it was something on the detector. I would have the detector replaced.
