Hello
Could someone please recommend the size of SWA i would need to supply a cu in my garage.? It is ingle phase.
The run of cable will be approximately 23metres. The cable needs to handle a compressor connected via a 32amp plug, a mig welder connected via 32amp and various power tools. Not all the same time though.
I understand that the tails from the meter will have to be split using Henley Blocks and an switchfuse installed. Can anyone advise on how much power suppliers charge for pulling the main fuse and installing a switchfuse please.?
I was thinking of 16mmsquare 3 core, with an earth rod and enclosure at the garage end of the swa. Is this correct procedure regarding the earth, with the cable run being over 20meters. I have read on this forum that it is not recommended to export the earth over long distances.
Any advice would be greatly appreciated.
Thanks in advance.
Thanks in advance.
