Swiftflow 80 problems
20 Sep 2007
I had some problems with a swiftflow which I rectified, new fan and faulty combustion cover. When I started up the boiler the heating works but the hot water does not, it worked perfectly before changing the fan ......
Any info appreciated :confused:
You dont say if you are CORGI registered or a DIYer!
Did you disconnect the DHW switch? Easy to short the two connections to see if it starts the boiler on DHW.
But then if you were CORGI you would have known that.
The fan probably only needed cleaning properly.
Tony
Thanks for the tip Tony
Formerly CORGI registered but mainly did servicing not breakdowns.
