Just bought a new house and surprised to see a number of switches and even a socket (with round holes) that don't appear to be used for anything. Even the previous owners have no idea what they are for. So, I plan to remove the switches and the socket, connect up the cables to terminal blocks and then fit blanking plates. Is this acceptable?
In the lounge I found a live cable sticking out of the wall that had simply been taped up and not very well as the live core was sticking out. Very dangerous. When we viewed the house this was hidden behind a picture!
I've removed the cable from the channel running down from the ceiling - this is different to the old plaster, so obviously an addition to the house, which was built in 1935. I can see the cable disappears into the bedroom above. Unfortunately it is NOT accessible as a false wall has been built around a fire place directly above this point and so this would have to be removed. It is also the other side of the joist, so can't get at it through the floor boards above.
I understand it isn't safe to leave live cables in walls, but without a LOT of work and cost, I'm struggling to know what to do. I was thinking of cutting the cable as close to the ceiling as possible, fitting some connectors and taping it up. Then fit a protective metal plate over it and then plaster. Hopefully, there is very little chance of anyone drilling this high up the wall and if they did, the plate would provide some protection. Alternatively, I guess I could fit a back box and a blanking plate, but it would stand out like a sore thumb in the middle of the wall!
I would appreciate your advice.
