Reminds me of The Two Ronnies optician sketch: "Oh, I only need glasses for reading - And seeing."
all connectors must be accessible if they are the screw type.
You need to get a "Maintenance free" terminal block, and safely terminate the cables there.
I hope that you remembered this...all connectors must be accessible if they are the screw type.
It's not formally defined, but is largely down to common sense. In particular, 'within a wall' or 'under floorboards' is not usually regarded as 'accessible'. On the other hand, above a top floor ceiling and accessible via the roof space usually is regarded as 'accessible'.Define accessible!
Unfortunately it is NOT accessible as a false wall has been built around a fire place directly above this point and so this would have to be removed. It is also the other side of the joist, so can't get at it through the floor boards above.
They are not, any more. Or at least, they should not be.So, if 'under floorboards" is not usually regarded as 'accessible' why are "standard" junction boxes used to connect cables?
When it's accessible.When would you ever be able to use a "standard" junction box rather than a "maintenance free" terminal block?
Probably.In my house ALL cables are "within a wall" or "under floorboards". So does that mean none of them are accessible?
All those who have wanted to comply with the Wiring Regulations since 2008.I would be interested to know how many people have used these "maintenance free" terminal blocks.
There's no exemption from the regulations because MF JBs are more expensive than non-MF.Let's face it, they are expensive for what they are:
Mainly because they were installed prior to the regulations requiring them to be accessible. In some cases of more recent installation because people have ignored (or been unaware of) the current regulations.So, if 'under floorboards" is not usually regarded as 'accessible' why are "standard" junction boxes used to connect cables?
In the past, anywhere. For new JBs, only if they are 'accessible' - as I've said, in an accessible roof space is probably one of the most common situations - or if a JB can been accessed through the hole after removal of a removable downlight.When would you ever be able to use a "standard" junction box rather than a "maintenance free" terminal block?
Probably - but they were very probably installed at a time when there was no requirement for accessibility, so they are still 'OK'.In my house ALL cables are "within a wall" or "under floorboards". So does that mean none of them are accessible?
No electrician should have installed any inaccessible JB which was not "maintenance-free" since the regulations changed. Many non-electricians probably are not even aware of the current regulation, so may well be failing to comply with it.I would be interested to know how many people have used these "maintenance free" terminal blocks.
..... in an accessible roof space is probably one of the most common situations - or if a JB can been accessed through the hole after removal of a removable downlight
They should also not be used there because they have no cable restraint.I was wondering about that, as the electrician that changed all my 12V downlights to 240V used standard junction boxes to replace the transformers and that was only about 4 years ago. But I guess these are accessible through the hole by removing the downlight fitting.
Indeed, that is true of 'standard' JBs. However, as you are aware, there are non-'MF' JBs made for that purpose which do have cable restraint. The requirement for restraint has, of course, existed for a lot longer than the requirement for inaccessible JBs to be 'MF'.They should also not be used there because they have no cable restraint.I was wondering about that, as the electrician that changed all my 12V downlights to 240V used standard junction boxes to replace the transformers and that was only about 4 years ago. But I guess these are accessible through the hole by removing the downlight fitting.
