- Joined
- 27 Jan 2008
- Messages
- 23,861
- Reaction score
- 2,699
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
There is nothing stopping you from filling in either a minor works or a installation certificate and you can either down load from IET web site or copy from 17th Edition.
However you will need some instruments and the serial number needs entering on the forms and it should have a traceable calibration record.
When "Borrowing" from work this is a problem as if anything went wrong you can't get access to calibration record.
In the main the likely hood of something going wrong is slim and in most cases one can borrow the test equipment without a problem. However you must make a judgement and if it is likely you may be questioned over it may be safer to hire the test equipment so there will be no problem with calibration.
Having said that while working as Electrical Engineer I sent a PAT tester to be calibrated. I also bought some software to enter all the results with and found I needed the pass level from the calibration cert. On looking I found this had not been entered so asked firm for the traceable record. They could not supply it and had to re-test the PAT tester which was then found could not be set to comply with new regulations and should have never passed in first place.
So I would not be unduly worried about calibration. With the exception of the time on the RCD tester all other calibrations can be done in house and that way one knows they have been done.
Homer British Museum
