Evening all, first post and I am hoping you knowledgable people will be able to help me. I recently had a new Ideal Logic+ combi installed but the installer connected to the old BG programmer and thermostat. I have since discovered that the heating doesn't go off when the desired temperature is reached. The thermostat clicks off but the boiler keeps heating. I have tried getting the installer back but they are messing me about. An Electrician I called out has referred me to heating engineer.
I have eliminated the stat and the programmer as the problem. I suspect it's the wiring in the boiler. There is one wire with a terminal block which I suspect is the problem. But know idea where it should go before I blow the whole thing
View media item 88991 [/img]
