sadly dindnt work stilll tick tick tick, i even went up in the roof enlarged the hole and tried to stuff foam between the copper and the ceiling but didnt work sadly, any other suggetion please??
does it sound like a mechanical tick and is it a regular tick that ticks at a regular time ? or is it irregular ? switch the boiler off at the boiler thermostat so that it isnt heating and switch the heating and Hot water on at the programmer, is the ticking still there when the boiler is off ?
its an irregular tick, will even tick when every thing has been switched off (like its cooling down) im 99% sure its just expansion and what with the same pipe being cold in the roof and hot in the airing cupbard.
