Hi all,
my initial thoughts was to build a car port in front of the double garage, but having second thoughts I thought, why not just build a timber extension with a flat roof??
In regards to planning, I think I can do it under permitted development. The house is not near a road, from the front of the garage to the front of the house is about 7.5m distance. the whole driveway (which goes in front of neighbours house) is part of my land as per photos in blue, and it would be a flat roof, max 2.5m height.
Would you think is feasible to do it as per my rough sketch? I'd keep the garage doors in the brick garage, literally would be a timber extension so I can keep the cars in...car port, but closed. Maybe even extend to the side of the house, but I understand if its attached to the house then needs planning...but if I leave a 1" gap... then doesnt need planning as its not attached anymore hahaha!
..would it be possible to build on the tarmac? or would it have to be concrete?
how would you do this if at all?
thank you
JP
Property boundaries
Here you can see on satellite the boundaries, and how far back from the house the garage is. blue circle is where I'd plan to do the extension
rough sketch
thank you
JP
Property boundaries
rough sketch
