Hi all,
I had a decorator round today quoting to do the hall stairs and landing. There is a lot of woodwork to go through!
I have emphasised the fact that the main focus is on quality rather than speed and cost (I want a top end job).
I am going for an eggshell white finish on stair posts / spindles / skirting and door frames with a decent solvent based paint (not water).
I know a bit about this topic but by no means am an expert and am well aware of the 'in between coats' rubbing down to get a good finish.
However, and I really hope someone on here will tell me I am wrong, I always thought you finished with simply the final good fine coat of paint NOT 400 Wet n Dry (wet). This is what the decorator has recommended to get the best finish - that is last thing he does is wet n dry (not paint). I kind of understand the thought process here, because obviously he will achieve that incredible fine finish you get once you have completed the wet n Dry. And not the slightly rougher paint finish. But with risk of repeating myself, just thought you finished on paint (not wet n dry).
Could anyone tell me if this chap knows what he is talking about before I part with a reasonable sum of money. Sounds wrong to me.
P.s - Anyone know of the best solvent based eggshell on the market for hall stair spindles / skirting / door frames etc?
Thank you!
Chris.
Thank you!
Chris.
