to install 2 motion dectectors (3-way) on the same circuit
24 Sep 2007
I have a problem, and hope you can help me.
I have to light a private way (road).
I use 7 led flood light along the way (about 500W). (on the same circuit)
1 - I would that the projectors switch on at the night coming. (with
a photocell sensor it works).
2 - Now I would like to put tow motion detectors (at the beginning and at the end of the road).
So I don't know if it's possible to put 2 motion detectors in 3-way ?
Or is there a possibility to do it ?
In fact When each motion detect something I would like that all lamps
swith on.
Thanks a lot and have a nice day.
Bruno.
wire each to a relay.
the relay then over rides the dusk - dawn sensor
ok thank you, but I don't think it's answering to my question. (my english is not very good).
So In fact I would like that lights swith on only during night and only when one or both of motion sensor detect something.
votre anglais est meilleur que mon Français. jet loin les photocellules alors vous avez besoin de 2 relais et de 2 sondes de mouvement, aucune photocellule. cela fonctionnera quand l'une ou l'autre sonde de mouvement voit le mouvement quand son obscurité
Hey thanks a lot for your answer.
Alors 2 relais et 2 sonde de movement.
Donc avec 2 motion detectors, I have to add 2 relays. is it that ?
What kind of relay should I buy ? and how to plug it in my circuit ?
Merci beaucoup...
c'est vraiement tres apprécié :)
Si vous avez des model de relay (reference) et /ou a schema would be very great :)
