Thanks folks - yes rough diamond is what this cottage is (I will be posting shortly about the fireplace) but at least I am hopefully getting it at a price to reflect the work needed.
Maybe I should invite you all to a DIY house party ha ha. I could do with an electrician, a builder, a plasterer, a plumber, a HETAS bod..... Where's 60 Minute Makeover when you need it?
PS it's a lovely part of Cumbria. Bring a bottle and a trowel
This is true. a good engineer designing a product that will reliably provide a function for the end user will use proven technology as far as possible. Leading edge technology is often high risk.
Often a new technology is developed and then the task is to find a market for it. Making people believe they must have the item when they don't really need it.
Indeed - but, in addition to that, as I said, 'off-the-shelf' technology is not only 'tried and tested' but is also likely to be much more readily maintained (or, indeed, replaced if necessary). 'One-offs' (whether or not they use 'cutting edge' technology) are fine so long as they remain under the control of the designer, but may otherwise present problems of maintenance, and often can't even be 'replaced' by others with any ease.
See for me (also as a design engineer) its the other way round.
Everything I can have off the shelf I will have of the shelf, I am very prepared to spend money and make compromises if it saves my time and allows failed parts to be swapped out with ease. Life is too short.
For lights, I must say, I find a switch works really well, on for 'I want light now' off for 'I don't want/need lights anymore' and some nice current carrying copper in between. KISS.
I do have a heated bathroom mirror, which required me to combine a heating unit with a mirror of choice, comes on with a second pull cord which also runs the fan.
But lighting wise only thing I would consider going more complex that what is available at screwfix would be a solution to dimming the living room and dinning room lights without having to listen to a 50hz humm on wall of the very room I am trying to relax in. Otherwise, all other rooms are on cheap non-dimming CFLs and LEDs anyway.
In principle, I feel the same. However, one has to remember, in the context of this thread, that the discussion arose in relation to a means of having ELV wiring to light switches - not necessarily for any 'clever' ('automation') reason, but in order to avoid having LV switch wiring.
