toilet pan outlet height
15 Oct 2006
hi could anyone tell me if there is a standard height of the toilet pan outlet
, I would like to know as I have to put in a tee piece soil connector for two toilets in two different room but one toilet has not yet been purchased
and will be a problem to put the connector in at the right height unless I can get a dimension
thanks col
I wouldnt panic about the second pan, obviously with a run in the 4 inch waste, you will be rising all the time, How far away is second pan ?.
Either way using different pan connectors, maybe an offset one would do the job.
hope that helps
Al
