I have just fixed this problem and wish to show how easy it is to solve.
The shower worked fine but after the off button was pressed water would continue to drip from the shower head.
I first checked the resistance of the solenoid as per the video on Shower Doc
and this was OK so assumed it was probably a bit of crap in the solenoid valve stopping it shut off completely.
See bottom left in photo, solenoid is brown, has wires attached and is pushed onto the valve.
Trouble is the valve can not be removed without taking the unit apart as the large plastic nut is bonded on. What you have to do is saw the pipe just below the nut, this then allows the valve to be pulled down and out after taking the 2 screws out.
TRITON sell the replacement VALVE AND SOLENOID FOR £19 without the large plastic nut so it can be slipped back in place easily.
This fixed the problem and only took an hour.
NOTE: SHOWER DOC PRICE FOR VALVE AND SOLENOID IS £35 AND THEY WRONGLY DIAGNOSED THE PROBLEM.
