Two way hallway socket with outside light
As it is, one of the yellows is the switched live.
As you say that the light does not go out when this switch is operated, that means the yellow is always live (except when the other switch is 'off') therefore this switch is not working as it should.
Edit - assuming the other switch is correctly wired and the lights worked properly before.
