Along with many other sparks too, I shouldn't wonder.
I have no doubt, that be true!
Apologies - I misunderstood you. It was probably your reference to "4D5A" which confused me - are you saying that there was such a Table in 16th ed? (in the current regs, there is a 4D5 {and a 4D2A}, but no 4D5A).No! Flat cable with CPC, as stated in table 4D5A, the only table I am aware this is mentioned, therefore applicable to the standard T&E.[I presume you mean 4D2A] ...
There is unless you are stupid or perverse. Or barmy - I will allow that as a 3rd option.That's what it should say but, as written, there is nothing about the wording which prevents one using 4D2.
I think you are on dangerous ground if you start saying that flawed readings of the regulations are acceptable when they stem from an insufficient knowledge of them.In any event, as I said, 4D2 should be able to 'stand alone' for those who have not looked at (or aren't even aware of) 4A3...
The 16th had a 4D5A.Apologies - I misunderstood you. It was probably your reference to "4D5A" which confused me - are you saying that there was such a Table in 16th ed? (in the current regs, there is a 4D5 {and a 4D2A}, but no 4D5A).
I stand by what I said. In any sort of document, Tables, Figures etc. should be able to 'stand alone'.I think you are on dangerous ground if you start saying that flawed readings of the regulations are acceptable when they stem from an insufficient knowledge of them.In any event, as I said, 4D2 should be able to 'stand alone' for those who have not looked at (or aren't even aware of) 4A3...
Thanks for clarifying. Do I take it that there was also a 4A3 (or equivalent) in the 16th which directed one to 4DA5 for T+E?Yes the 16th had a table 4D5A which is as table 4D5 in 17th, the table 4D2A are same in both 16th and 17th
That would be Table 4A2 which directs you to table 4D5 (which only exists as 4D5A in 16th, as there is no reference to the second letter of any tables under "Applicable Current Rating Tables" column) Much as it does for 4A3 in 17th.Do I take it that there was also a 4A3 (or equivalent) in the 16th which directed one to 4DA5 for T+E?
Did we ever get to the bottom of:...My simple solution would be to take a spur from that RCBO to an FCU, fused at 13A, sited next to the consumer unit. ...
(particularly the 16A bit) ??Heating system is rated max 16A with the elements I have totalling a shade under 12A.
If your surmise is correct, then I agree with your conclusion.16A is the max the controller will switch. \His fixed load is 12A, so a 13A fuse is cushty..
Indeed - but, as I indicated, that was not really my concern.Yes I would be happy. ... The >2KW guidance for loads on a ring final is to prevent a concentration of large load(s) on the ring.
Exactly, and that was my concern. Given that it appears that this is the only 'downstairs sockets' circuit (presumably including kitchen and any utility room), I was wondering whether, with that 12A 'fixed' load, one's design calculation would estimate the max demand as being under 32A. Even with diversity applied to the UFH (is one allowed to with UFH - I'd need to look that up?), just a couple of appliances (say a washing machine and kettle) together with the UFH would probably get one close to, if not over, 32A. I suppose it depends upon how the designer regards 'max demand'.The main consideration would be the total load on that CPD, so it depends on a calculation of the max demand on that 32A breaker with the 12amp added in without diversity.
