True, but they could unplug it, if they wanted to plug in their cleaning machine!I guess if something important does get plugged into the cleaners socket, the cleaner can't switch it off by accident.
In data centres I have worked in the cleaners sockets were identified red to distinguish them as being 'dirty' power rather than the desk sockets that were fed from the building UPS.
Yes, if you have an appliance where you don't want it to be permanently powered. I used to have a kettle where the switch was in the base, not on the kettle itself - very easy to accidentally knock it on, and much better to have a switch on the socket than the plug for the kettle lying on the worktop.That's obviously what it facilitates, but is there really any need for that?
I obviously could not claim that I never encounter such situations, and the emergence of wallwarts has created a good few of them - so I was wrong to make such a blanket statement. However, with the exception of wallwarts, most appliances/equipment have their own 'adequate' (and usually accessible) switch, and that is what I would normally use.Yes, if you have an appliance where you don't want it to be permanently powered. ... And so it goes on - I am truly amazed that you have never in your life encountered a situation where it's easier to use a switch than remove/replace a plug.That's obviously what it facilitates, but is there really any need for that?
So now you can stop wondering.I've often wondered .. whether there is any particularly good reason why any sockets are switched!
Because a few other things have come to mind.Facilitating the safe removal of a damaged plug (without de-energising the whole circuit) is about the only specific thing that immediately comes to mind.
Switched Sockets, have their uses - Ideal for the lounge, as you can switch off your telley and freeview box properly, and save expensive electricity in the process (and the safety advantage too)
To be fair, I have to put my hand up and say that I sort-of did - in a way which I now accept was far too much of a generalisation. However, I have to say that, speaking personally, with the exception of wallwarts, I very rarely find myself switching off a socket.I don't think anybody is disputing the advantage of switched sockets!
To be fair, I have to put my hand up and say that I sort-of did - in a way which I now accept was far too much of a generalisation. However, I have to say that, speaking personally, with the exception of wallwarts, I very rarely find myself switching off a socketI don't think anybody is disputing the advantage of switched sockets!
