Myself and my neighbour share one common waste water pipe to a very small cesspool tank but we have to empty it sooo often because it cannot take the capacity. We can't split the usage cos the pipes were installed under the floor all already joined.
So, we had they idea of putting in a valve (the pipe is 110mm upvc) that can be closed (automated is preferred but manual will have to do) and therefore divert the waste into the second cesspool.
Ie: I use water and the valve opens the pipe to my cesspool. If I don't open it, the waste goes to the neighbours cesspool.
It is a good solution - but is there anything out there for upvc pipe?
I see lots of metal valves for heavy duty pressure etc but not for plastic pipe.
Any ideas if this exists and where I can get, and what it is called?
Thanks,
JD
Thanks,
JD
