Urgent Help Please With Heating Issue!
18 Dec 2006
Worcestershire
Hi All,
I have a modena 80e model boiler and have just attempted to fire up my central heating. The issue I have, is I can get no heating to kick in, and no light indicating that it is even ready.
I have bled all radiators, pressure is at 1 bar, and nothing is happening.
I am still receiving hot water, and when I turn off the hot tap, my central heating standby flashing light appears for a few moments before flashing off again.
Please help if you can! Many many thanks in advance.
I take it you've checked to make sure your time clock/progammer is calling for heat :LOL:
Many questions.
I want to know if you have a piano and a dog.
Does the radiator symbol light up
Many questions.
That's fine - no and yes are the answers!
The radiator symbol will only light up when I have run the hot tap. It will turn off again after a few minutes
Hi All,
Further to this, is there any reason this would occur on any boiler, not just an 80e? It's as if it wants to kick into CH mode, but it's just not happening.
Any suggestions welcomed. Thanks again.
strange one.. I would reckon the micro switch is saying there is a constant demand for hot water therefor not allowing the central heating to be heated.. or the micro switch is fine and its the diverter valve spindle is stuck and holding down the micro switch.
These are just guesses mate I would need to see it, I hope you check and find out its one of these.
someone else will come along shortly and advise you further no doubt..
Thanks matey.
Is this something a mere amateur could look at ** or would I need to call the big boys in?!
**Obv only consider if it involves pressing a button or something!**
ok so that i dont get ripped to pieces by everyone. I'm going to say get a big boy in lol.
but say... if you had the manual and knew where the diverter valve was you could at least check the pin if you knew what your looking for but then again a big boy would be advised also make sure hes gas safe.. ;)
Thanks matey.
Sorry all, even further to this, this is the first time I have attempted to use my CH since April. Is there a mechanism that would shut it down if unused? I have tried reset etc to no avail.
