here's photos of one being installed
http://www.ultimatehandyman.co.uk/forum1/boiler-a-half-t2428.html
http://www.ultimatehandyman.co.uk/forum1/boiler-a-half-t2428.html[/QUOTE]
Where is that located?
It is a beast and I think the 837 will do just fine for us.
i dont know where that one is located but mine is in the loft.
If you have the room for it and want the hotwater performance then choose the 937, or else the 837 will do.
Yes it should be but speaking with a local plumber today he slightly put the wind up. Saying with a bigger house we would be best to go for a sealed system and a Vaillant 630 and hot water tank. I shall need to consider as we have 13 rads but one bathroom and maybe a shower unit to be added later. No more baths/ensuite.here's photos of one being installed
Although the size of a combi is determined by the hot water performance, the heating requirement is just as important. The 937 can only modulate down to 12kW - below that it goes into on-off mode. 13 radiators does not seem all that large - I have that and it is fed from a 14kW non-condensing regular boiler.... saying with a bigger house we would be best to go for a sealed system and a Vaillant 630 and hot water tank. I shall need to consider as we have 13 rads but one bathroom and maybe a shower unit to be added later. No more baths/ensuite.
David - in a bathroom cupboard? icon_eek.gif Really? Please post a picture.
A combi boiler will not run two bathrooms at the same time. Combis are should be used when space is at a premium. If you have a loft put a boiler cylinder and tank up there and possibly a pump if you like decent showers. Some one will also suggest and unvented horizontal cylinder which are ok if you want to pay for a £150 service charge every year.
What makes you think you need such a large boiler? Is your house enormous?We would only need up to the EcoTECH 837 combi if we took that option or the Vaillant 630 system boiler if we went that way.
As I have said earlier, check out what size boiler you really need for heating using the Sedbuk Boiler Calculator. I would be very surprised if you need a system boiler larger than a EcoTEC plus 618.
The 837 suffers from the same problem as the 937 - it can only modulate down to 12kW, which may not be low enough for your house.
Floor area is not enough to go on; there are other factors to consider!You may well be correct but isnt the one down from the 837 the EcoTECH plus 831? This goes down to 8.7kw (& up to 24kw). Would 12kw be too high a start point for an internal building space of 1631sq ft?As I have said earlier, check out what size boiler you really need for heating using the Sedbuk Boiler Calculator.
Instead of speculating, why not use the Sedbuk calculator - then you will have an accurate answer. The heating requirement could be anything between 6kW and 20kW, depending on windows, insulation, construction and location.
The only measurements you have to input are: length, width, room height and number of floors. You do NOT have to work out the window area; it will be estimated for the type of house. The answer may not be 100% accurate; but it's better than guesswork.Had a look at that calc item and it was asking for all sorts of measurements which I do not have, like windows etc.
