Valliant Combi Boiler
15 Feb 2007
Essex
Hi
My valliant boiler is coming up with a F.22 message. We have no heating or hot water.
We had a plumber come over and spent all morning on the boiler (to say that he could only temporarily fix the problem - but we would need to 'flush' the sytem out. Anyway, after he left the boiler ceased to work.
Any comments = would be gratefully received.
BW
Its a Vaillant 824 or 828 !
The code is for a lack of system water flow.
Its measured by the temperature sensors and they can give problem trips if they are a little off tolerance.
The earlier boilers were too sensitive and later PCB software has been modified we are told.
Officially the poor flow is caused by a blocked or weak pump, dirt or air or a blockage in the system.
What the actual cause is in your case is I dont know without being on site. Clearly the "plumber" you had there is rather less than competent! I would suggest you call a boiler engineer!
Tony
