Does anybody know where I might obtain one of those plastic ventilators that gas companies used to fit in windows whenever a gas appliance was installed? The reason I ask is that one such ventilator broke into pieces when I removed it for cleaning and I need to replace it with a new one if possible.
The glass is a sealed double-glazed unit which is 16mm thick and the hole is 120mm diameter in the inner pane and 150mm diameter in the outer pane.
The ventilator has a spinning fan-blade in it but there is a hit-and-miss cover that operates with a pull-cord so you can close it when ventilation is not required.
Enquiries at my local hardware store resulted in the expected, "ain't seen one o' them for years mate".
The other thing I'm looking for is "spirits of salt", otherwise known as hydrochloric acid. I want this for turning a copper roof green without waiting a few years. Apparently if you dissolve zinc in the acid and then apply it to copper, you get the desired "verdigris" without the long wait.
Best wishes,
paul
Best wishes,
paul
