Right.. after almost a year we now have a free ish flowing drain.
I installed a manhole, and 2 rodding points and have had dyno-rod in to jet the whole lot out and its now flowing.
What I want to do now is stop it getting blocked up again.
The main culprit is silt im guessing from leaves and the like. but there was also some gravel and a teaspoon in there!
id like to construct some kind of sieve at the upstream end where the pipe enters our property. i think it would be a silt trap.
is there a commercial product that will do the job? or should i dig a simple hole, concrete and brick sides? then perhaps a mesh guard over the outlet pipe?
the only other complication being that the pipe is quite close to the house. so would having a hole be problematic for the foundations?
its under half a meter away.. maybe more like 250mm.
refer to the diagram in the OP. im talking about the bottom left of the image where the pipe goes under the fence.
cheers.
cheers.
