Very noisy tap!!!!!!!!!
KOR
14 Sep 2006
Hampshire
Every time i flush the toilet the cold tap on the bath vibrates, its extreamly noisy and very annoying. The sink tap isn't effected and it doesn't happen if i run the bath tap while flushing. If anyone can help with the cause and solution i would be greatful. Cheers
A low pressure float valve insert fitted on a high pressure water feed can make for some very noisy results.
You could try adding some fixing clips to the cold water pipework where possible.
