Vokera 24 compact - DHW intermittent now worse
4 Feb 2004
Morning all,
My vokera 24 was having issues with hot water supply in that it used to run hot cold hot cold but it wasnt too bad as long as you put the shower on a couple of minutes before you wanted to use it it would sort of settle down and provide hot water constantly. However now ive put the central heating on in the morning it is much worse. It seems to provide much shorter time of hot water before running cold for longer. Is the boiler now "hotter" with the CH on causing some kind of safety device to cut in a stop the heating of the water?
Phil
