Vokera SP80 no hot water
10 Dec 2010
Roxburghshire
Hi all,
Our SP80 Excel boiler is not giving any hot water. The central heating fires up fine no problem so we have heating.
When i turn the hot water tap on the falcrum arm does not move out, however if I press the arm at the bottom left hand corner of the arm to move it out at top right then the boiler fires up. Once I release the arm though the boiler steps down.
When I press the arm to get the boiler to fire up for hot water there is a definate click sound so does this mean the microswitch is ok?
Is this a case of replacing the domestic diaphragm? I have come across some posts saying it could be the DHW microswitch which should be located bottom left of the falcrum arm but I can't see anything there.
Any help or advice would be appreciated
Mike
That would usually be the cause if the arm is not moving.
Tony
Yes, is the answer to both your original questions but I was mainly answering you second question.
Tony
