Obviously I've not used these before so don't know if it would be as easy as he makes out but thought I'd share it.
If I do get a tool for placing anchors (seems like people think this is a good idea?) do they accept different sizes of anchors for hanging different items?
The link is a US site , the plug shown is nylon, you can can simply unscrew wall plug unless it's the metal type fixed with setting tool which leave a large hole .
I have been in houses where the owners have paid 400 - 500 k but the handrails and curtain poles are always loose because the walls are made of plasterboard. If I was spending that much money, I would expect a solid wall with proper plaster on it. Our old house which was worth half that amount was built in the sixties and had block internal walls which was fine.
In other words freddymercurystwin, what I'm getting at is, there are SO many variables/possible problems for just using a simple plasterboard fixing. For the average diy-er or beginner... just buy the setting tool and be done with it!!!!!
Too right. "Curly-whirly" (Redi-Driva) type wall plugs might be removeable, but i find that they can start spinning in the PB when you install them (especially in thinner PB) and their load-bearing capacity is minimal compared to the umbrella-type. The setting tool for umbrella-type costs peanuts to buy and will repay its cost many times over in reduced frustration and failed fixing installations.
That's just plinn shoddy, cheapskate building. TBH you don't need a block or brickwork wall behind the PB, but as a minimum you do need at least 12mm (better still 18mm) plywood pattresses let in between the studs. This is still common practice on many commercial builds (restaurants, hotels, schools, offices, etc) for radiators, WCs (e.g. for toilet roll holders, sinks, etc) but domestic housebuilders seem completely unaware of the need for it. Priceless!
It's true that umbrella fixings can leave a 10 to 20mm hole, but it is fillable, and in any case when you remove a "curly-whirly" they also leave a large hole......
