Hi, i have two wall lights in my lounge which i need to remove. What is the best way to kill the power to them as i dont want to leave live wires in the wall. Thanks.
Can you work out how the circuit is wired? The wall lights will probably be fed from either the ceiling rose, in which case simply disconnect from that point, or from the light switch. You'll probably need a multimeter to work out which. Are there two cables at one wall light and one at the other?
If you're not sure how to identify the cables, give us a photo of the ceiling rose, light switch and wall light connections and we should be able to make things clearer.
