Hi all![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Have just stripped the roof timbers off an out building only to find that the flank walls to both sides run out of level by possibly as much as 6 inches from one end to the other.
This is info provided by the bricky who says it will be tricky to level this out with brick work and for it to look reasonable considering the building is in a conservation area.
There will be a facia but no sofit at the eaves as these have to be left open to match the rest of the house
The new roof is a cut one with 7x2 timbers and the ceiling inside is vaulted.
Question is if the wall plates are running out of level does this mean that every set of roof timbers will have to be pitched at different angles?
Have a few ideas to level the plate up but wondering if any of you seasoned vets out there have come across this before and have the solution to hand.
Thanks in advance for any help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
